Wingrider
- Northern Virginia
I have a couple of terms from the NEC that seem to cause questions in the field.
What is meant by 'securely fastened' as used in the NEC? I have seen several different attachments, including; tie-wire, ty-wraps, bent nails, using refrigerant line supports, etc. Is there any way to make installing contractors use proper conduit straps for their installations? I can't seem to point at the NEC and declare their technique a violation if it meets the distance and secure portions of conduit installations.
What is the interpretation of 'Accessible'? When applied to wiring methods the NEC says, "Capable of being removed or exposed...." Does the exposed part mean that if I can get a beam of light on the LB, box, etc. it is exposed? Or, should it be required to actually touch the fitting?
