- Placerville, CA, USA
- Retired PV System Designer
Is it already committed to being all in parallel on one circuit, or is there an option to run it off more than one control?
160312-1522 EST
George:
In post #1 you did not explicitly state .
You need to know what the specifications are for a control element and how those specs relate to a controlled load.
In town we have what at one time was claimed to be the most powerful laser in the world, and it still might be. I also believe the statement may have been made that its output power was greater than all of the generating capacity in the world. How can this be? It is really a function of what the words mean.
You need to know how devices work, and their characteristics to determine how different devices work together.
The interaction of fluorescents, CFLs, and LEDs with dimmers is a jungle.
I am looking to dim 650W of LED lamps on one switchleg. From what I can discern, the best i can get for Lutron is 250W.
Leviton claims a 1000W dimmer for LED. Is there fine print I am missing, or is Lutron sucking wind on this particular front?
From post #9:Edison base A19 LED replacements.
Dennis, educate me: power booster...?
After further review, I think Leviton's spec sheets are simply incomplete. "These work with LED" and "This is a 1000W dimmer" do not equal "This dims 1000W of LED".
Not sure how to tackle this one. I think that for the moment, the room is not dimmable.
Okay, I tried installing a shunt, but now every time they turn the lights on the breaker trips. They said to get out and never come back, and don't bother sending an invoice. :ashamed1:
Edit: did I use the wrong one?
http://www.amazon.com/Siemens-Q12000.../dp/B0052MDNSWLast edited by George Stolz; 03-08-16 at 01:24 AM.
I didn't want to spoil all the fun; ask for the time, get detailed instructions on how to build a nuclear submarine. Another typical day on the forum. It may prove useful to some.
I don't know how to say it more plainly, but here's another attempt:
72 lamps x 9 watts apiece = 648W.
There does not appear to be a dimmer that will handle this.
Good hunch.
All one switch leg, not interested in rewiring the church to break it up into multiple switch legs.
We have to assume all these posts relate to the same problem or question. Next we assume this existing circuit has a dimmer, likely rated at 650 W incandescent, and there are the equivalent of 650 W of incandescent bulbs on the circuit now.
For convenience assume 11 60 W incandescent bulbs is the present maximum load. To provide approximately the same light output with LED replacement bulbs will require about 11 9.5 W LED bulbs, or an average power of 9.5*11 = 105 W. This is well below the mentioned Lutron LED maximum of 250 W.
On CREE I measured a peak repetitive inrush of about 2.25 A and of rather short duration, about 30 microseconds. A dimmer with a load of 11 LEDs would produce a repetitive peak of about 25 A. Is this unreasonable for the likely size of solid-state switch in the dimmer? Probably not.
If the goal is to increase the maximum light output on said switchleg, then information on that is needed. Comparing all of the posts on the problem or question does not provide a clear indication of what the problem or question is.
iwire:
UL primarily relates to safety, and not directly to whether one or more products work well with each other.
Incandescent bulbs made with a tungsten filament for a given voltage, power, and lifetime were very close to one another from one manufacturer and batch to another. This is not true of LEDs, or even dimmers.
It was fairly easy to define the capabilities of a dimmer with respect to incandescent bulbs, and specify the dimmer in terms of the maximum wattage load. Not so simple for LEDs.
It is my opinion that having a reasonable knowledge of how dimmers and LEDs work, and what are their characteristics and limitations can greatly assist you in working with and combining these components. Your ccokbook approach may work for a minimial system, but may be of little value to troubleshoot a problem.
Just because I have a thing about finishing off comatose horses....
George, was your comment about a shunt in post 19 a joke?
Are you still interested in a dimming solution, just not interested enough to search very far? Or has the ship sailed?
Just an off the wall idea if you have space available and the components are still available:...
To my knowledge the client is still awaiting an option, is aware of my roadblock, and I assume that if I came forward with something that fit the bill I would be hailed as a genius. Or competent, or slow, but eventually on point with solutions.
Thank you for the links.
I may have missed something, but George has 72 Edison a-19 bulbs....
Were these originally 60-watt bulbs?
Like 4320 watts of incandescent? 36 amps on one switch leg?
Hmmm. I wonder if this switch is turning on the coil of a 3-pole contactor?
Idk, just thinking into my keyboard
George said, as I recall, "some kind of CFL"....
right. But I don't recall whether that was the original building lighting or if that's simply what was in place when he arrived
Alrighty. I just thought....wouldn't it be funny if he was trying to dim a contactor coil?I think it is pretty clear that that 72 fixture circuit was never incandescent!
It just seems conveniently divisible by 3.....24 lamps, 12 amps, etcHear hear! When I returned with my notes and started doing some math I noticed the same thing - there could be a contactor involved in the present setup, but if the magical 650W dimmer fell out of the sky then I was going to deal with that as a gimme.
