G
Guest
Guest
Re: Dining Room Receptacles
How does 210.21(B)(2) and Table 210.21(B)(2) factor into the comment above? That table may be the source of my confusion and the source of my current MO. It can limit the cord-and-plug connected load to 12 (1440-watts) amps on a 15-amp receptacle (even if on a 20-amp circuit). I'm not saying it makes me right, I'm only pointing it out as a possible source of the confusion.Originally posted by hurk27:
Awwt:
How are you going to run a hairdryer more than 3 hours?we have overloaded a 15-amp circuit if we put a 1500 watt hair dryer on it
Continuous Load. A load where the maximum current is expected to continue for 3 hours or more.
210.20 Overcurrent Protection.
(A) Continuous and Noncontinuous Loads. Where a branch circuit supplies continuous loads or any combination of continuous and noncontinuous loads, the rating of the overcurrent device shall not be less than the noncontinuous load plus 125 percent of the continuous load.
