ceknight
iwire said:The definition of lighting outlet tells us in no uncertain terms that a lighting outlet is an outlet intended for the connection of a luminaire.
That means it is a lighting outlet before I install the luminaire on the box.
What makes it a lighting outlet and not a simple J-box?
The fact the installer intends it to at some undetermined point in time have a luminaire fastened on it.
I almost hate to jump into this one, but fun's fun.
"A lighting outlet is an outlet....." says the hymnbook.
The hymnbook also says an outlet is "a point on the wiring system at which current is taken to supply utilization equipment."
So....if there's no utilization equipment being supplied (...), then there's no outlet. And if there's no outlet, there's no lighting outlet, either.
The intent you've honed in on serves only to distinguish between different sorts of outlets, Bob. It is, basically, what turns an outlet into a lighting outlet.
Funny thing happens on this interpretation....intent becomes de facto irrelevant. If it's not an outlet until current is taken to supply utilization equipment, then it's not a lighting outlet UNTIL a lampholder, luminaire, or pendant cord is actually installed. Which means that you can only signify intent by installing a lamp instead of, say, a duplex receptacle. Pointing and saying "hey, that's supposed to be a lamp box" won't cut it.
Chris Knight
Syracuse NY
