And that changes 314.29, how?[/QUOTEi
Iwire asked you;
OK than I expect you will start failing all installations with boxes above suspended ceilings.
You responded;
We should, there is nothing in the wording of the code to permit that installation.
Then I responded with;300.23 Panels Designed to Allow Access. Cables, raceways, and equipment installed behind panels designed to allow access, including suspended ceiling panels, shall be arranged and secured so as to allow the removal of panels and access to the equipment.
