72.5kv said:If you have unity power factor than VA=Watts. This means that the phase angle between the voltage and current is zero. If that is not the case than VA will be larger than Watts.
LarryFine said:Here's a plain old English explanation.
Simply put, a wattmeter is an electric motor whose speed depends on both the voltage between line terminals and the current through the lines. The wattmeter actually responds to volts and amps (volt-amps), not watts.
Voltage peaks twice per cycle, and current peaks twice per cycle. A wattmeter measures power by simultaneously measuring the voltage and the current, and then 'calculates' the power consumed as what we call watts.
If the voltage and current peaks occur simultaneously, the volt-amps and watts are genuinely the same, but if there is a time difference between the two peaks, the wattmeter turns slower for a given amount of volt-amps.
However, in spite of a deceptively-low wattmeter reading, the power system must be sized to safely carry both peaks, whether they occur simultaneously or not. Since the voltage is a given, the current is really the variable.
The circuit must be designed for the voltage and the current. The insulation doesn't care what the current is (of properly-sized conductors, of course), and the (properly-insulated) conductor doesn't care what the voltage is.
Power companies and electricians alike must design the system components to safely carry the voltage and the current, not the power. Poor power-factor results in a system that must carry current not useable by the load.
To answer the OP directly, yes, for the sake of Plugmold, you can consider VA to equal wattage. Since voltage is considered to be a constant, amperage is the variable that must be accomodated. I hope this made some sense.
weressl said:The simplest way to think of it is two people trying to pull a block of concrete, one guy is named Mr. Amperes and the other one is simply known as Volts. If they line up along a single line to pull, all their strength will be fully additive. when they are trying to pull in different directions...
crossman said:That is a worthwhile analogy. Another analogy is having the volts and amps pulling in the same direction, but at different times.
Example: Volts says "one two three PULL!" but Mr. Amps is kinda lagging behind snoozing. He thinks "Oh, I should pull now!" but Volts has gotten tired of pulling so he has already started slacking off as Mr. Amps starts to apply maximum force. Therefore, the peak pulls never match up to give full force.
This example actually works better for illustrating two currents out of phase such as can be found in LCR parallel circuits.
When either of the above analogies are used to illustrate power factor, they don't show that there are both positive and negative powers created which must be averaged in to get the Watts.
I like using sine wave graphs of voltage and current, with another graph of the power found by multiplying I with E at each instant in the cycle.
Is that REAL?!brian john said:This should explain it adequately.
walkerj said:Is that REAL?!
brian john said:Yeah they're mine had an additional blue line, but the state police had something to say about that. And as LAZ says I am nothing but a BIG "0" so they are fitting.
