Not at all. I maintain that it's origin simply is not relevant, any more than the fact that
factor is from the Latin word
facere.
As I said, are not discussing the English word
factor, we are discussing the technical term
Power Factor.
That is not what I said. I said that one does not ignore a variable in an equation simply because one possible value does not change the final result.
This entire discussion arose from a question about KW compared to KVA, where someone responded that KW = KVA * Power Factor. In the simple case of a sine wave, the power factor is the absolute value of the cosine of the phase angle between the current and the voltage. As you pointed out, the Greek letter Phi is commonly used to represent the phase angle, thus:
KW = KVA * |cos
Φ|
The variable we call Power Factor most certainly has meaning in this equation.
How would you have us solve this?
if |cos Φ| = 1KW = KVA
else
KW = KVA * |cos Φ|
endif
Pretty silly, don't you think?
Ah, now comes the red herring. I'm not discussing HOW you solve equations. I'm merely pointing out that one does not ignore variables in the process. Like it or not, 1 is a possible value of the cosine of an angle.
