weressl said:1 is a meaningless factor.
Maybe, but it is a factor!
rattus said:Maybe, but it is a factor!
weressl said:....of course it is WHEN it is LESS than one. Factor means "change". The number 1 does not change anything. It's math.![]()
weressl said:OK, go ahead and arguew with the mathematicians and the dictionary.
You can't redefine English just because it became misused in the vernacular.
Just like my name remains LASZLO regardless how many times you spell it differently.
It is cosine(fi) not theta.
I see no way you can refute that argument.
Well, if one is a non-contributing factor, or otherwise not a factor, I guess readers can disregard any ONE of our posts :grin:weressl said:OK, go ahead and arguew with the mathematicians and the dictionary.
rattus said:I have always seen it as "Lazlo", I will spell it correctly from now on.
The choice of symbol is rather arbitrary, I think. Now I did not learn engineering from the dictionary, so I refer to my texts and handbooks for the definition of power factor which includes the cosine function.
I don't have any argument with the mathematicians, they say the cosine varies from -1 to +1, therefore the PF can be one.or zero.
weressl said:I don't know how you can see it any differently when replying to my posts since it is part of my signature from day one.
Cosine Fi is the term identified in the Fink&Carrol Standard Hanbook for Electrical Engineers, Section 2 Electric and Magnetic Circuits, Para.159 Power and Power Factor, Sine Waveforms.
"... and Fi (I imposed over O) is the phase angle between the two(E&I), the cos Fi is being known as the power factor of the circuits."
The mathematicians argument is in the formula of expressions. In additions or subtractions when the value is 0, the value is not indicated as it is not germaine to the value of the sum. The same is true to the number 1 in case of multiplication or division. That is why I said, yes and no.
LarryFine said:I think Rattus would tell you that X and 1 are both factors of X, such as in: X * 1 = X
Told ya!rattus said:Even prime numbers can be factored with one of the factors being one.
220/221 said:I didn't try to understand therefore I didn't get confused.
LarryFine said:Told ya!![]()
But, of course! :smile: I already believed the same way.rattus said:Larry, someone had to say it! You almost did.
weressl said:You can't redefine English just because it became misused in the vernacular.
brian john said:Have you seen teh History Channel show The History of the English Language?
Mike03a3 said:The plain English definition of the word factor isn't relevant to this discussion.
We can, and do, "redefine English" by compiling dictionaries of words and phrases used in Scientific, Engineering, Medical, Legal and countless other professions and occupations. Look at all the threads on these boards that revolve around how the NEC defines or uses words.
In this case, we are not discussing the English word factor, we are discussing the technical term Power Factor. Since it is defined as the cosine of the phase angle between the current and voltage, the value certainly can be either 0 or 1. You would not disregard a variable in an equation simply because it has no effect on the result in the unique circumstance where the value of the variable happens to be 1.
LarryFine said:Okay, here's a simple test:
How many factors are in the equation: 1 * X = X
