Tulsa Electrician
- Tulsa
- Electrician
What does mfg say in the instructions. Any local amendments.
Hopefully not.What does mfg say in the instructions. Any local amendments.
The only reason the ground/neutral prong being up is more correct is that the right angle plugs molded on the appliance cords won't hang right and makes the installer look ignorant, but not sure a inspector should be requiring it to be changed. This only applies to 30/50A devices, smaller ones can be all over the place.
It will get locked at 100 posts!I agree. And normally this thread would be locked.
However, (there's always a however in life), I have seen rational electricians become irrational inspectors.
Ron
Or if it wanders off the specific topic of dryer receptacles (not outlets).It will get locked at 100 posts!
A shot over the bow!It will get locked at 100 posts!
What do you have against Range receptacles? Do we risk having to open a new thread just for them?Or if it wanders off the specific topic of dryer receptacles (not outlets).
I could see if someone made a cord with SO cord and an end that isn't 90d then either way would work and be find but that is a very odd situation to be in since appliance pigtails are cheap and commonplace.As mentioned it's not a code requirement but IMO it should be installed so that the angled cord isn't folded over since it's just a better installation. If we installed it ground down I would have it changed to ground up.
Not saying there isn't one but I don't think dryer cord caps are made in anything other than ground away from cord entry.I could see if someone made a cord with SO cord and an end that isn't 90d then either way would work and be find but that is a very odd situation to be in since appliance pigtails are cheap and commonplace.
I read this somewhere: The grounding terminal should be oriented towards the top of the receptacle, to prevent objects from falling down B/T the face plate and the plug.Inspector made us change outlets , so Ground would be on top. Is their any code that states
this has to be this way. New construction apt bld.
Thx
Ron
This will all get more complicated when we have standardized orbital construction and "up" has new meanings hahaI read this somewhere: The grounding terminal should be oriented towards the top of the receptacle, to prevent objects from falling down B/T the face plate and the plug.
That is a recommendation, not a requirement.I read this somewhere: The grounding terminal should be oriented towards the top of the receptacle, to prevent objects from falling down B/T the face plate and the plug.
Personally, I love the "Happy Face".That is a recommendation, not a requirement.
IMHO it would be lovely if receptacles were angled so that ground and neutral were upBut I'm not going to advocate for requirements on the topic.
Back to the OP, I agree with the others: receptacle orientation should be set for minimum strain on the cord path, but this is a best practice, not a code requirement.
Jon
Supposedly reduces the chances to 50/50 of a short is the reasoning, but then it increases the chance of the ground prong not making contact on a loose plug, even though most are longer. RV plugs have the same issue especially with a wp in use cover.I read this somewhere: The grounding terminal should be oriented towards the top of the receptacle, to prevent objects from falling down B/T the face plate and the plug.
The last one is perfect for ungrounded dryers
