scottkilgore
Re: Econmics vs workmanship
Re: wraping solid wire around screw.
I use the hole on my strippers to bend a "U", then put it around the screw and crip it closed around the screw. I strip just enough that when I crimp the wire it bends 270degrees to 300 degrees tight around the screw. That way the wire will not fall off or squish out while tightening. they may touch but never cross.
With stranded wire I strip about 5/16" off then strip another 5/16" down and pull it just past the end of the wire strands to hold them. I then wrap the hand twisted bare part around the screw accross itself making an "X" under the screw then tighten while holding the "X".
As I said on the last post I will do what it takes time and material wise to be workmanlike and economic. this method prevents call backs, fires, etc. that's economical even though it takes longer.
