wwhitney
- Berkeley, CA
- Retired
Sorry, post 99 doesn't answer the question. Post 86 suggests the answer is yes, but I want to be clear.[Ennui]See post #99.[/Ennui]
Cheers, Wayne
Yep, and it refers to the 300.2 definition, not some earlier definition from some earlier version of the NEC.Type AC cable is used in the Code
I grant that in past codes old BX cable armor without a bonding strip was compliantly used as a grounding means. So if you want to verify whether an old installation was done compliantly at the time, you'd need the old Code books.Please get some old Code books and school yourself.
If we ignore the 320.100 issue, I'm going to agree with you on the above, with the elaboration that the NEC also says it has to be "low-impedance". [250.118(8) => 320.108 => 250.4(A)(5)]
Now, what is adequate and low-impedance? The obvious choice is to look to the UL standard for armored cable. Its first standard for maximum "ohmic resistance" for armored cable was adopted as advisory in 1929 and mandatory in 1941 (Sleights, section 2.2). That standard is 1.5 ohms/100 feet for #14 armored cable (it has since been lower).
Among the combined samples tested by Dini and Sleights, less than 10% met this standard.
I think this has been touched on but I will mention it again, it is sort of like the issue a few years back when standard compression fittings were deemed no longer acceptable as raintight fittings. Though I think that was a joke, you don't see everyone rushing out to replace all the previously existing fittings that are in areas that get wet.Al, reading this thread as an outside observer your position seems to be that since AC-without-bonding was once a code compliant EGC that it must still be a code compliant method because it hasn't been specifically rescinded?
That would be like saying it's acceptable for me to wire new houses in K&T. Codes and standards constantly evolve, so I really don't follow that argument.
My position is, because "Armored Cable Type AC" is the cable that the 1913 NEC thru to the late Fifties NEC required to be installed (when the rule in the Armored Cable article published the change in the construction of the cable to require the bonding strip) was not changed to Armored Cable Type AC-B (or some other changed "Type" designation the way NM changed to NM-B) there is, today, no way to make 2014 NEC 250.118(8) apply only to one Armored Cable Type AC over another type of Armored Cable Type AC, in my opinion.Al, reading this thread as an outside observer your position seems to be that since AC-without-bonding was once a code compliant EGC that it must still be a code compliant method because it hasn't been specifically rescinded?
Your continued refusal to educate yourself in the historic living Code in an attempt to execute verbal "gotchas" is transparent.
I'm certain there are plenty of BX installs that will adequately clear a fault.
But there seems to be evidence that some of them won't, and create a fire hazard in the process of trying, hence the amendment changing the description of AC to include a bond wire.
Residential Electrical System Aging Research Project
July 1, 2008
David A. Dini, P.E., Underwriters Laboratories Inc.
Armored Cable first appeared in the 1903 NEC, but didn’t become popular until around 1930, and is still a popular wiring method today. The armor of AC cable systems is tested for grounding and can provide a suitable equipment grounding path. AC cable made after 1959 requires a No. 16 AWG aluminum bonding strip under the armor to help improve the conductivity of this path.
So let me ask how do you evaluate whether it is an "adequate path for fault current"? I don't believe you've addressed that.To directly answer your question, 2011 & 2014 NEC 250.118(8) declares that "the armor of Type AC cable" is an acceptable Equipment Grounding Conductor, with the caveat to evaluate it as an "adequate path for fault current".
Regrettably, "adequate" is not explained procedurally by the NEC and we have to collaborate with AHJs and clients to solve the meaning.
And what would you propose? How would you advise an AHJ to determine adequacy? Details, please.Regrettably, "adequate" is not explained procedurally by the NEC and we have to collaborate with AHJs and clients to solve the meaning.
There you go again.And what would you propose? How would you advise an AHJ to determine adequacy? Details, please.
Cheers, Wayne
