- Placerville, CA, USA
- Retired PV System Designer
Not necessarily. It could, for example, transfer energy to an electron, either free moving or jumping from one energy level to another.Turning into heat, right?
In an appropriate semiconductor junction they can excite an electron (or hole) to move from on side of the junction to the other. This is what happens in a photovoltaic solar cell.
In ordinary insulating material, like glass or brick the electrons are promoted from a captive electron shell to a captive shell with higher energy. At some point the electrons will drop back down again, giving energy in the form of light or heat, just not immediately.
Pretty much. The incoming is mostly visible and UV, as water in the atmosphere blocks out most IR. Once a photon hits a surface and transfers that energy to an atom, that energy is transferred to another atom (conduction) or sent back out as lower frequency IR (radiation).Is this why light hitting a surface turns to heat energy?
Sure, an insulator starts to conduct or leak current at some voltage. But if that voltage is high enough to initiate considerable current, it would cause destruction of the insulator : thermal runaway.Electrons tightly bound, doesn't everything start conducting at some voltage? Even porcelain begins to look like copper?
In some practical cases electrons will move along the surface via resistance of surface contamination and ionization of air or other gas or liquid at gaps before the breakdown of the insulating material itself is reached.Sure, an insulator starts to conduct or leak current at some voltage. But if that voltage is high enough to initiate considerable current, it would cause destruction of the insulator : thermal runaway.
Just a practical consideration to add to the theoretical. Breakdown in the bulk insulator, unless current is somehow limited, will generally result in destruction
Sent from my Pixel 4a using Tapatalk
Of course, a solid insulator would be destroyed due to excessive leakage current. But a liquid or gaseous insulator would not: only electrical breakdown happens.Sure, an insulator starts to conduct or leak current at some voltage. But if that voltage is high enough to initiate considerable current, it would cause destruction of the insulator : thermal runaway.
I think you inadvertently omitted "not" before "washing". Correct?Is this why washing dirty insulators causes flash over?
I’ve washed MANY insulators with a pressure washer on a 115kV line close to the coast. Never had one flash overIs this why washing dirty insulators causes flash over?
I don't see the water itself as a conductor causing flashover, but I could see it interacting with dry surface contaminants to create a conductive path interrupted only by gaps small enough to break down.NERC reports say otherwise. It has happened.
Wow, interesting video, would never had considered spraying water onto high voltage like that, working from the adage "electricity and water don't mix".Before anyone says I meant otherwise see this:
