alfiesauce
I call mine- the terminator
because it's a terminating screw driver.
Sorry, no pix. :-?
480sparky said:Another idea came to mind tonight:
When working with threaded rod, and you need to run a nut a long way onto the rod, here's a neat trick I learned years ago.
Works great when you've got a lot of them to do, such as when you're building multi-layered trapezes.
One of these guys. The wider bristle version works great. You dont have to hit the nut dead center on the wheel.
It will scream up the threads.
today i had to trace some circuits but i didnt have a circuit breaker and i didnt want to flip breakers on and off because of computers.
heres what i did to help
i grabbed a heat gun, plugged it into the receptacle and went to the panel with my ammeter. i tell the helper to turn it on and i check the phases for the extra 15 amps the heat gun drew. once i found the phase i went down each side of the breaker until i found one with 15 amps on it. i tell the helper to turn it off and the amperage went away. it worked better than an actual tracer IMO
the $25 ones at home desperate? tried one once. after getting really
frustrated with it not being able to find the right panel, let alone the
right breaker, i gave it to my friend mark, and he tried it, and then i think
threw it against a wall..... now we both own ct-326b's.......:smile:
what about keeping insulation off your skin so its not uncomfortable to crawl around attics? i was in hell today. lying down across joists 2 feet on center through blown in insulation.![]()
Hire a helper or change jobs. :wink:
Do your layout on the floor with blue painter's tape to mark the centers, and shine up with a laser plumb bob.
You seriously wanna take half a pay cut to work in Florida?![]()
As opposed to a full pay cut? :-?
In areas where dust control is important, drilling through a wet sponge helps.
