LarryFine
- Henrico County, VA
- Electrical Contractor
I'd rather patch a 1/4" hole than a 3/4" one.I use my see snake for this now.
A "thermostat screwdriver" works great on most all of them.Does anyone else have trouble removing the wire from quick connect terminals? Some are easy, but others try men's souls. I find a small scratch awl wedged between the spring and plastic case works fine on the Slater brand.
Of course a pair of side cutters is probably the best tool for the job!
Anything special about a thermostat screwdriver? I don't think I have one.
AKA jeweler's screwdriver.
What I call a thermostat screwdriver is one of those little screwdrivers, often with a pocket clip, that are freebies different places. They frequently come packaged with certain items that have small terminal blocks, and are great for thermostats. They work perfectly for releasing backstabs.
Some also have small magnets on the top ends as well to test small relays.
Another idea came to mind tonight:
When working with threaded rod, and you need to run a nut a long way onto the rod, here's a neat trick I learned years ago.
Take some duct tape, and wrap it around the chuck of your cordless drill, sticky side out. 3 or 4 layers should do it. Place the tape lightly against a nut you've started on the rod, and make sure your drill is set to run in the correct rotation. Pull the trigger. It takes a while to get used to it, but it's pretty easy to learn. Soon, you'll be zipping those nuts up the rods so fast everyone else will be amazed.
Works great when you've got a lot of them to do, such as when you're building multi-layered trapezes.
I've always used one of these instead. Saves tape, works great!
Sounds like a great idea for the newbies. :smile:The old journeyman I was working with gave me a short piece of 12 solid wire and told me to bend the wire the shape I needed the pipe to go and it would help you remember better or have something to compare it to when you got to the bender. It worked really well.
