cadpoint
- Durham, NC
I'd recommend charts, graphs, pictures... small slide shows to liberate a conversation point or stear one!
A hand out of the same subject matter U Display in Hand they can consentrate on you, prepare accordingly...
Be ready to demonstrate both backwards and forwards any math you present, cause and effect, 2 equations that will show your work, again backwards if someone gets lost.
Re-explain an equation high points in a final sentence on subject!
You can present overhead equations, CPU or flat projection's to roll with your chalk board talks, quick route with the board, the Projection is what they will take notes on... presenting and stating with graphic's is worthy!
Work to a summary with your board work... the overheads should build then summarize your presentation. Again you chalk board could be minimal bases on a complete set of hand outs...
It's work, be prepared 150% at best, your'll do 75% to 110% of what you want to present nighty, hourly, or daily, What Are U teaching Again
If a multi - lesson class ask for some person history of the electrical field
Reason for taking class....
Ask if there's certain questions that have, having worked in this vocation?
U can lecture on that subject... or just mention it later in 2nd or 3rd nighty,
hourly, or daily.
Talk, one or two optave above what your conversation level is...
U'll have a responsive adult class, again be prepared. Good Luck ...
hourly, or daily.
