splinetto said:...I am estimating 300 hole total....
You might to give this number to the HO ~ 1-800-233-5917
You can't handle the truth!!! The truth is that is how we do it...And everyone does it that way...Ok not everyone. But everyone around here.....I will tell you this I do pull more than 1 phone or tv thru a hole...Can you atleast give me some slack for that?stickboy1375 said:Okay I want a truthful answer, why on earth do you do this?
splinetto said:You can't handle the truth!!! The truth is that is how we do it...And everyone does it that way...Ok not everyone. But everyone around here.....I will tell you this I do pull more than 1 phone or tv thru a hole...Can you atleast give me some slack for that?
It is not like some guys do and some guys dont...We all do....And if you came here you would have to do the same.....You might try to fight it but the dark side is strong....peter d said:"Everyone does it that way."
When was that ever a good reason to do something?
splinetto said:It is not like some guys do and some guys dont...We all do....And if you came here you would have to do the same.....
Give him a break! It is the "show me" state!peter d said:When the blind lead the blind, they all fall into a ditch.
Sounds to me you have some clueless authorities there and people who are willing to go along with their absurdity.
Show me a code secton I am violating.peter d said:When the blind lead the blind, they all fall into a ditch.
splinetto said:Show me a code secton I am violating.
You forgot hands,arms and shoulders.peter d said:There is no code section. The issue I have is that drilling all those holes is a ridiculous waste of time and effort. Not to mention wear and tear on your bits and drills.
No, with a brace and bit.bjp_ne_elec said:That's how Popeye got those forearms. Knocking out 300+ holes a house with a Hole Hawg![]()
I've never heard of people counting how many holes they drill when wiring a home. Do you guys factor that number into the cost or estimate somehow? And if so then why?bjp_ne_elec said:That's how Popeye got those forearms. Knocking out 300+ holes a house with a Hole Hawg![]()
steelersman said:I've never heard of people counting how many holes they drill when wiring a home. Do you guys factor that number into the cost or estimate somehow? And if so then why?
celtic said:For me...that cost is included with the wire run ~ even the times when no hole is being made..ie, homeruns across basement/attic ceilings.
steelersman said:Yeah I can't imagine trying to figure out how many holes I'm gonna drill so I figure out an estimate based on that. Seems like a waste of time.
One day, they'll figure out that's a violation if you're working with a 20 amp circuit. I know there's still lots and lots of people who continue to improperly do that, though.We can't use 14 anything here in NM except between light fixture and switch.
When I say walk drill the handle of the drill is held down to an easy on the back with out bending level and the other hand runs the drill. Right or left thigh applies pressure to the drill. That 90 degree drill was one of my best investments.
