stickboy1375
- Litchfield, CT
The reason I dont drill from the hip is because its a waste of labor and wire, I drill exactly 8" up from my outlet boxes, I use less material and my labor is faster.
How are your back and knees....and how old are you ?![]()
I know for me that would take longer for labor, expecially considering you snap a line just to drill.The reason I dont drill from the hip is because its a waste of labor and wire, I drill exactly 8" up from my outlet boxes, I use less material and my labor is faster.
yeah I actually use a Hilti cordless 18 Volt with standard 18 inch auger bit.Dont you guys use the milwakee drill with the extension ont it? or Boom drill as we call it. hole hawg......wow that hurts my kness just thinking about it......
I know for me that would take longer for labor, expecially considering you snap a line just to drill.And all of that just to save about 20 feet of wire?
you are nuts!!20' ft of wire? are you kidding me? do the math. then talk the talk.
exactly!!My holes are about 12 above the box so 4 inches times 60 outlets and switches in the last new house I did cost me 240 inches of wire / 12 = 20 feet. Seems I came out the same.
I use a right angle drill:
exactly!!![]()
One word "SimPull" Romex won't bind unless a kink is in it.
you are nuts!!While you are doing the math and snapping lines and bending over to drill I'm pulling wire already.
yeah roughly. Maybe 15. Ooh an extra 3 inches.You drill at the hip, but your 12" above your receptacle boxes? :-?![]()
