Expensive screw
I don't see any se cable. The overhead looks like bx when I enlarge it and the cable in the shower looks like 10/3 nm. Are my eyes that bad?
It's a flat concentric se cable
(2) #4 or #6 hots with very fine neutral strands around amounting to probably #10
Can't tell for sure the size of the hots because the insulation is so thick, but right where it blew apart, the one hot moves rather easily so I'm thinking #6
Price tag for one screw is about $5,600
I was at a job years ago where a lady flooded her whole house trying to repair a toilet and broke a pipe and didn't have the slightest idea where to shut the water off.
I don't know what the damage estimate was but I'm sure it was more than $5,600.00.
At least here all that work needed to be done even before the accident. Just hope the remodeler had good liability insurance.
It seems unfair that the remodeler should carry the cost of the upgrade beyond the repair. Had the remodeler damaged an old two wire receptacle, then they would need to get the receptacle replaced, not upgrade the circuit to a grounded one.
At the same time it is unfair to burden the homeowner with paying for an upgrade when their existing system (while in violation) was probably working just fine.
What do you guys think is fair?
Jon
Jon
He should be responsible for the repair, unfortunately for him the repair in this case requires a whole new service.
It's unfortunate but He will hopefully learn a lesson from this experience.
Jon
Also How was their existing system in violation? As long as it was to code when it was installed it is perfectly legal. It becomes in violation once this contractor put a screw thru it causing it to be replaced
Jon
I would say, Life isn’t fair.
Contractors deal with a tremendous amount of risk. You screw up someone’s dinner in a restaurant, you toss it and make a new new one.
Put a screw though a service entrance cable in an old home, and well, we see what it costs.
Contractors need to charge enough to make managing that risk, worth their while.
Jon
I didn’t read anywhere if the remodeler is a licensed contractor or just a handyman.
Were permits pulled? Just how far is this going to go? Is he working by the hour for the HO?
Its amazing how one little oops can escalate. I’ve had a small oops turn into a mountain before.. it sucks.
why should the remodeler be responsible at all.
Should off had a nail plate, Its was who ever installed it the first time issue.
Since its not complaint any damage he may have cause he should not be responsible for
I get he could of put one but unless he altered that stud , not his problem
If I am crawling under a house and none of the plumbing is strapped properly, and I am climbing over, and under it and something comes loose, I am not paying a dime
I'm with you. That cable was improperly routed and didn't have a nail plate or the proper clearance.
