He can do it.Who is going to stop him?
I've seen that with zip cord as well. I blame the brittleness more on the fact that it probably was overloaded at times than the fact it was zip cord.
This is an 18 ga conductor supplying general use receptacles on 15, 20 amp circuit, or even in old places maybe someone put in a 30 amp fuse.
But if you keep load to within it's rating it still maybe doesn't last as long as other approved methods for use as permanent wiring.
That's funny, I have extension cords that my Grandpa owned, that are over 50 years old, and still in excellent condition. The insulation is still soft and very flexible with no cracking.NM though has some flexibility to it isn't intentionally designed to be used where it is flexed while in use.
Outer sheath of NM is thermoplastic and lasts longer than most flexible cords that often are rubber or synthetic rubber based.
I was in a house a good number of years ago that the previous HO used zip cord. Everywhere.. I insulation would crack as you touched it. I've seen SJ cord do the same. I would expect the low cost import cord will do the same because if the goal is to save $$ on this install, I suspect we won't be spending a lot of money on this 18 AWG extension cord.
Maybe you're right, I didn't feel, see it. Neither did the owner. Dang.I collect extension cords like some people collect rocks. I have dozens of brands and thousands of feet of extension cord. Not one single cord has disintingrated over time due to age.
Only by UV exposure (and only after many, many years) or by over current.
A relative has a 40' SJT cord strung from an ourstide outlet, over a tree branch, and into one of those Rubbermaid portable sheds. It's been there 10 years, at least. I try to remember to look at it every time I'm there. The insulation has discolored in the sun, but it's still soft and flexible and shows no sign of cracking.
It's not even a Southwire, Carol, or Woods, etc. It's the Lowe's store brand, made in China.
The only cords I'm really, really, afraid of is the Home Depot brand orange SJT cords. The outter insulation on these is very soft, very flexible, and very thin. They fade to white in the sun after a very short time, and the thin, soft insulation tends to twist and loosen, causing the internal conductors to start pushing out and stretch it.
Try hanging out in the Christmas decorator groups. Those people use thousands of feet of cheap China SPT-1 cord to make zip cords. I've never seen anyone complain about the insulation breaking down.
