AC\DC
- Florence,Oregon,Lane
- EC
Installing 600 amp, 3phase 208 system to old building. Transformer vault 18 feet away from CT enclose.
Will be installing 2-3" pvc conduits with 500 kcmil xhhw, Core drilling into the vault.
Attaching To 48",36" Ct enclosure installing Current transformer mounting base with lugs
installing CT meter socket 24" from Ct enclosure
Coming off CT enclosure to 600 amp Fused Disconnect with 2- 3" 6' long pvc pipes
Installing 2- small 3" stub and lb from Disconnect, diving into crawlspace
Running 2 sets of 3" pvc from crawlspace 30' to old 3" EMT 90s that feed into Large load center.
Load side of Disconnect will have additional ground wire in it
Pulling wire and to all noted system and old Load center.
Putting this into my estimating software got around
53 Labor hours.
Parts are about 10.5k
Total price for this listed job is $24k
Does this seem to high - decent - or to low.
I know you have to look at the job but
I still have to come up with a price for line side of Transformer since I have to run pipe for the power company and run there ground ring.
Attached is a quick look of the layout decking is all going away. I am not doing the trenching
Any ball park figures would be appreciated.
53 Labor hours.
