GarwoodV6
- Houston suburbs
- 30 year commercial Electrician
I used to put this arrangement for residential portable generator connection via mechanical interlock. If the panel is inside an unfinished room, I would wire a length of SO cord into the side of the panel, hang it up in the room, and feed the cord through the wall via a pvc bushing or sleeve to a weatherproof box and extra-deep in-use device cover to house and protect the male cord cap. Open the cover, pull the cord out, and - voila!
If the panel is outside, you can put the cord into a cabinet or under a cover to protect it from the weather. Either way, the interlock keeps the male cord cap prongs from ever becoming a sefety hazard.
