That is awesome. Take my money!
they did, and it is. showed up on porch half an hour ago.
showed spouse how it worked. her inner frugalator was appalled
at all those electrons dispersed as heat from stuff all over the house.
what is cool is that if you look at the shots you make with the viewer
in the app, swiping a finger down lets you look at the jpeg under the
scan. it's the same temp outside today as inside, so studs in walls don't
show up distinctly, not enough delta.
rafters however, would, if the attic weren't R-30 batts laid crosswise to
each other. there is a small hole in the bedroom where a batt got moved,
it seems. a square about 1' x 1'.
seems to be moisture along the edge of the wall near the shower
under the tile in the hall bathroom. crap.
ignorance was bliss.
