.....But you are, I think, arguing against a switch being at an outlet........
Yes I am.
..... I believe that Outlet is as opposed to inlet .........
I gotta ask this Al..... is there any egg nog in your house. Or was there an hour ago?
I believe that Outlet is as opposed to inlet.
What is it that seems confusing to you?I gotta ask this Al..... is there any egg nog in your house. Or was there an hour ago?![]()
Actually, I don't have an opinion on what the CMP intends or wants, with respect to neutrals at a switch box, except for what I understand of what they wrote for us.
I believe that the core idea in the term "Outlet" is that of current being taken out (outlet) of the Premises Wiring (System), as opposed to the idea of the term "Service Point" which is the point at which current (taken by utilzation equipment) enters (inlet) the Premises Wiring (System).
I've explained this before, and I will gladly, again. The key in that definition, to my perspective, is in the use of "controller" in the last sentence, the sentence that lists the exclusions from the Premises Wiring (System). Wiring internal to appliances, luminaires, motors, and similar equipment are also included in the exclusions.How citing the definition of Premise Wiring makes a switch an outlet.
For the current to be "taken", it has to first be "given".
The Premises Wiring (System), all by itself, has no source and has no utilization equipment, essentially.
Asked and answered. I can't guess what the CMP intends.I simply asked if you thought the CMP intends, in say the application of 210.12, if a simple switch is an outlet.
........... The key in that definition, to my perspective, is in the use of "controller" in the last sentence, the sentence that lists the exclusions from the Premises Wiring (System). Wiring internal to appliances, luminaires, motors, and similar equipment are also included in the exclusions.
Wiring internal to controllers. . . the interior of the plain old snap switch fits that definition to a "T", when the snap switch is used as a controller of, say, a luminaire.
Because the current, passing through the switch, current taken by utilization equipment, has to leave the Premises Wiring (System) while inside the switch, that leaving is, to me, exactly an Outlet....
Al, I can't believe we are back here again, what's it been three years or more since the mega thread took place? We even had a poll.
I will ask one question, can you show us where "Switch Outlet" is defined in the NEC?
I can show you many "Outlet" definitions but I can not find one for a "Switch Outlet"
If a switch is an "outlet" because it connects two wires together a wirenut is an "outlet" too. :grin:
Roger
Why? It fits the definition.But why an outlet?. . . That definition tells you what parts are and what parts aren't premise wiring system..... not how to label them.
A smoke detector is installed at an outlet, even though there isn't a label "smoke detector outlet". -- That's also for Roger.![]()
Yes. .Definition of what? An outlet?
Yes. .
No.Just because of your opinion that it's not part of the Premises Wiring?
It could still be in his house, technically speaking.I gotta ask this Al..... is there any egg nog in your house. Or was there an hour ago?![]()
No.
As I said in post #23, the Article 100 Definitions of Premises Wiring (System), Controller, Outlet, and 404.14
And my opinion.
