mivey
BTW, That is not my position.tryinghard said:...who may be convinced 12 the only way to go.
That is not what I said. Read before you post!brantmacga said:...why would you put a 2-gang box and put one device in it? that looks like poo...
mivey said:...I have put in a 2-gang switch...
Me too! Sounds like we are doing a great job. Let's keep it up!brantmacga said:...my wiring plan takes into account a situation that may have too many wires at one location (like that one more hot you need to feed that other switch box), and allows me to know which lighting box is going to get the extra conductors...
I incorporated it into the design. It was not the way I laid out in the 1st draft but so what? The best I recall I was able to switch some spotlights from that location. If that would not have worked out, I would have done something else with the circuit layout. It is all part of the process.brantmacga said:so. . . out of curiosity, where does the other switch go? are we giving freebies now??![]()
mivey said:Then make your point and quit insisting that someone else run calculations to support your position.
Don't worry, I'm not offendedWe are all friends here.
[edit: typo]
No offense intended. Ride easy. Don't read too much into what is posted because text alone does not convey feeling. Website banter can be mis-judged way too fast. It's late, I was blunt. Sorry if I offended you.tryinghard said:I suggest you work on softening your tones you are offensive.
because I just see that as basic, common electrical knowledge.iwire said:It appears from your posts that you are unaware of NEC box sizing requirements.
From an NEC perspective 12 AWG takes up more space then 14 AWG.
mivey said:It would appear that you are not aware that how many wires I need in a box is based on what I'm trying to do inside that box, not the wire size. I use the box I need to fit the # conductors, devices, connectors, & fittings.
Changing the wires size doesn't change how the circuit works. I'm suprised you don't know this.
mivey said:Apparently, as long as you don't try to run a poll, anything goes:grin:
BTW I voted for "I use #14..." because I do sometimes. There was no option for having used both #12 and #14, depending on the situation.
#14 for the lights? I'm on board, for the most part. #14 for some dedicated circuits? I'm ok there as well. #14 for the general use receptacles? I'm just not there.bikeindy said:My OP had a poll built in I just didn't want to run a poll i think only 2 people ever answered any of the 3 questions. but the thread is about people who just won't use #14, most of whom I see are in one way or another comming around to see the light. and the light is wired with #14. so are the receptacles.
quogueelectric said:Who said I am putting it on a 20 a breaker??
mivey said:#14 for the lights? I'm on board, for the most part. #14 for some dedicated circuits? I'm ok there as well. #14 for the general use receptacles? I'm just not there.
There's the proof, right there baby!e57 said:OK lets just end all this non-sense right here:
BIGGER = BETTER
:wink:![]()
mivey said:There's the proof, right there baby!
I'm not so sure. Three grunts = I'm sold. One grunt = I'm not so convinced...sounds like a Jill Taylor imitation grunt:grin:e57 said:...Bigger means less voltage drop = [grunt]MORE VOLTAGE[/grunt] = better
Looking at the hot side of the receptacle,it could of been a bad connection at the device plug(heater,?)BryanMD said:Do you know what caused it to melt?
I doubt it's related, but that box is awfully far back from the GWB -no mudring etc.
mivey said:Changing the wires size doesn't change how the circuit works. I'm surprised you don't know this.
mivey said:I thought iwire, in jest, was being sarcastic when he said this:because I just see that as basic, common electrical knowledge.
Just thought you were yanking my chain. I just read it the wrong way. Sorry.iwire said:Why is it you always seem to go that route?
How does that help?
Let's assume all of the wires are the same size. If the wire is passing through unbroken and doesn't have too big of a loop, it gets one volume allowance. If it has a splice or termination, it gets two. If it is part of a set of grounding conductors, it is counted with the allowance for that set (the IGs can be another set). So let's just say it is not the grounding conductor, it does not originate in the box, and let's also assume it is not a luminaire exception, and let's assume we are talking about a conductor that is "cut" in our box: for a #14 it takes up 2 cu in and for a #12 it takes up 2.25 cu in.iwire said:So code wise how many CI does a single 14 take up?
