jaylectricity
- Massachusetts
- licensed journeyman electrician
emahler said:until you go over 3 hrs...then it's only 4 amps![]()
Heh...good call.
Tiger Electrical said:If the rest of the world uses 14 ga, Homeline & backstabs it doesn't bother me a bit.
emahler said:well heck, when you're running pipe, what difference does the wire cost make?
#12 stranded is easy to work with...#12 romex will wear you down....especially when you get old![]()
growler said:Now that you mention it I don't know why I should care either. Much of my work comes from back stab receptacles.
I should be promoting those things and maybe #14 as well.
Just why the heck did they take FPE panels off the market? We should lobby to bring those back. :grin: :grin:
Stab locks forever!!!!:grin: :grin:
20 on smokes??? Talking about overkill.hey_poolboy said:Just finished a house in a jurisdiction that would not allow any #14 in resi construction. I figured I may as well do all 20's since they make us use #12.
It is kinda sad and frustrating to not be able to run #14 for smokes or some lighting circuits.
ItsHot said:20 on smokes??? Talking about overkill.
Why, just put the smokes on with one of the bed circuits.ItsHot said:20 on smokes??? Talking about overkill.
growler said:Now that you mention it I don't know why I should care either. Much of my work comes from back stab receptacles.I should be promoting those things and maybe #14 as well.
emahler said:i said that every year we did resi service...cut every corner you can guys...just job security![]()
Minuteman said:Why, just put the smokes on with one of the bed circuits.
growler said:Eric, now that I think about it this recession may be my fault. Why did I have to use all those quality parts when there were perfectly good knock-offs made in China. :grin: :grin:
Dude, I can't use 14. No point in running a 20 amp JUST for smokes.bikeindy said:shoot it is a 20 amp circuit put the whole house on it unless otherwise required by code. 20 amps is the magic electrical circuit it will carry all.
LarryFine said:The question calls for generalizing when the answer depends on specifics. First, presuming we're talking about residential wiring, I like separating lights and fans from receptacles, which is no more expensive when the area calls for more than a single circuit anyway.
Then I choose the ampacity for each circuit based on the area and likely loads. For typical bedroom/bathroom/closet/hallway lighting, one 15a is often enough for a small house, two 15a circuits for a larger one, etc. I rarely use 20a circuits for lighting.
Then, I might use a single 15a circuit for a smaller house's bedroom-area receptacle circuit, a 20a if it's bigger, or two 15's, or even two 20's if the house is huge. I like to do the same for other areas, like living-rooms, dens, etc.
To me, lighting circuit loads are usually predictable, whereas you never know what someone might plug into a receptacle. Even at the same VA per sq.ft., fewer 20a circuits can handle one large load, such as the infamous vacuum cleaner, and often every light is on when the vacuuming is being done.
Smokes have to be on the master bedroor lighting ckt in my neck of the woods so it will be noticed and fixed quickly if there is a problem. I am not saying I dont use 14 wire I am saying I dont have to like it. I use 14 in my own house but I am using it for light loads like Fridge/dishwasher 14/3, Microwave/range hood. Lightly loaded dedicated ckts. You asked and I answered if you dont like the answer other than yours dont ask any more.ItsHot said:20 on smokes??? Talking about overkill.
I know I know I feel for you.Minuteman said:Dude, I can't use 14. No point in running a 20 amp JUST for smokes.
In case they're left on for 3 hours? (80% of 15a)ItsHot said:Why are all vacum cleaners now rated at 12 amps?
