My Mom said it looks very nice, in fact she hung that picture on her refrigerator.........
Well, that explains a lot.
what is the bending radius of 500? Can you stab through the back of a 4" deep box?
I could swear I've seen that building before. Is it anywhere near where the Royal Caribbian Cruise ships dock?
WOW, no kidding! Since it is rated for 75?C (167?F), it must really get hot in Texas to melt PVC.. . . In the Texas heat that thing will come down
the meter would have to have test-bypass blocks installed since it's a commercial install.
I did think that was odd, never used a 3? 400A base that didn't have a bypass. I'll check into that.
I made that mistake once, it can be expensive.:smile: Luckly it got caught before it cost to much.
Everything's bigger in Texas, even the tall tales.WOW, no kidding! Since it is rated for 75?C (167?F), it must really get hot in Texas to melt PVC.
On the other hand, if the service drop is supported on something other than the service mast, why not permit PVC to be used? The NEC doesn't prohibit its use, why should the local city or town?![]()
POCO will be tapping up the new service to the existing drop.
As long as it is not locked, you can use the select tool. Even if locked, there are other ways to skin that cat.Can I cut and paste from a PDF???
This is correct, I owe you one John.
Maybe you should use schedule 80 PVC that is rated for 90?C (194?F) and use expansion fittings?. . . Even if you strapped every 5' it will look like a velvet rope at a theater.
Is this a setup?
No way is this for real.
