ronnie-matic
- bucks county, pa.
i thought you did not have to jump gas hotwater heaters , hot and cold pipes only electric water heaters, is it in nec to jump gas water heaters or not to ground pipes.
georgestolz said:See 250.53(D)(1) for the requirement.![]()
Cavie said:Benaround is correct. Jumping out the water heater went the way of the outhouse a long time ago.
Agreed.benaround said:What I'm saying is lots of systems are already bonded together...
A water filter tends to seperate it's input and output without hope of the twain meeting again down the road. A water heater has a darn good chance of the two pipes meeting downstream.Ragin Cajun said:Guess I'm in a sour mood today. A water heater is a lot more common than a filter. Whay doesn't the code just say water heater??
This section would no longer apply, but 250.104(A) could be applied to the other half of the system. It just doesn't lend itself forward as well as 250.53(D) does.jwelectric said:What is 250.53(D) talking about?
(D) Metal Underground Water Pipe. Where used as a grounding electrode, metal underground water pipe shall meet the requirements of 250.53(D)(1) and (D)(2).Does this mean that if the pipe is NOT being used as an electrode (D)(1) and (D)(2) would not apply.
edamico11 said:, but my test proved to me a bond is needed..)
Cavie said:jumper not required with mixing valves
