I just learned that contractors have obtained a real 208Y-480D step up transformer. ...
Got a picture of that diagram/nameplate?Nope, wye-delta. Square D model V28M48T1516. Still need to ground a leg? Surprised the unit's wiring diagram doesn't show this.
Three phase transformers typically have delta primaries, step up or down. I couldn't find any info online for that particular model number.
Transformer diagrams do not show corner grounding of a delta configuration. Wye neutral and delta high leg grounding are the only grounding I've seen indicated on diagrams.
It has been said on this forum that the neutral of a wye primary should be left floating (i.e. not connected). I've never quite grasped the reasoning, so perhaps someone that does will explain it...
