izak said:" . . . A/C current . . .
LarryFine said:Yikes!
"This is a message from your department of redundancy department."
Just funnin' ya'!
boboelectric said:Pittsburgh,Pa. inspectors want GREEN screws.
Bob O.84,Pa.
iwire said:Roger you will not find a section in the NEC that says a regular screw is acceptable.
However you will not find a section in the NEC that says a regular screw is not acceptable.
The NEC does require that the grounding screws on devices (plugs, outlets, connector bodies, etc,) be green. This can be found in 250.126.
Another section to look at is 250.8
In my opinion this section is somewhat contradictory.
It says we must use listed means.
Two problems with that
1) There is no such thing as a 'listed' green grounding screw.
2) If we are limited to 'listed' hardware there should be no need to say Sheet metal screws shall not be used to connect grounding conductors to enclosures.
Personally I often use the clamp screws after removing the clamp.
Let the battle begin. :lol:
Minuteman said:Yuck! That just looks wrong.
iwire said:Thanks
And this looks 'right'?
How about a side by side look.
Typically we use the clamp screw but we normally use deep 4" squares with MC clamps.
I used the old work box in my photos as it was easy to show a 'cut away'
infinity said:We usually use self grounding receptacles so the tail to the device isn't needed.
iwire said:Most we use are self grounding but company policy is to always use a copper jumper.
If you read the job specs you may find many times you should be as well.
Most of the specs I see require the use of copper EGCs regardless of the other NEC compliant methods available.
infinity said:Around here we still have engineers specifying AC cable.
Minuteman said:The problem I have that the clamp screw is listed as a clamp screw and not a ground screw. Could you not do the exact same thing (strip a section of the green wire to go under a green screw, then connect it to the device's green screw)?
infinity said:Screws for EGC's do not have to be listed.
celtic said:Is there really the required 6" of free conductor here:
