Another C10
Electrical Contractor 1987 - present
- Southern Cal
- Electrician NEC 2020
I always seem to pull a ground, I remember one service call in particular at a car dealership were a 200 Amp splice box supporting some massive kernies, one being pressed up against the enclosure which had became so saturated inside from rain water pouring in through a "SS Conn", that before isolating it had noticed at the gear it fed you could literally see and hear arcing across all the nearby concentrics and connectors, it was a pretty amazing sight. That sold me on why using the metal enclosure isn't necessarily the best path for fault current. The main never tripped.
