electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
And that's the other thing. It seems like the importance of the EGC is over-emphasized IMO. Almost everyone is obsessed with it. So what if there is an occasional less than perfect fault clearing path? What are the chances that a fault will even happen, plus the chance that it won't clear, plus the chance that person or property will damaged? The obsession with grounding makes people not focus on other equally or even more important aspects of the electrical system, IMO.Stopped using all conduits to supply the ground to a device over 45 years ago. While in most cases it's acceptable never 100% reliable. Saw way too many EMT fittings pull apart, steel rigid conduit rust thru etc. Nothing safer then a copper ground conductor same side as the wires feeding 15 & 20 amp receptacles. Was taught that the ground conductor is the most important wire and that it should be the first conductor connected & last to be removed.
