Alright.![]()
This installation with a proper receptacles has been the case for a long time before the NM cables were made with the EGC.
Alright.![]()
Makes sense.
So I want to ask- is this receptacle actually UL listed?
Makes sense.
Why buy from CRC? Buy from an American company.
There should be a UL number in the documentation you can look up.
I tried to let the code articles and sections explain themselves. But I do agree, as others have pointed out, I wonder how it got listed like this as far as terminal identification . Something is definitely fishy about this. Please educate me. Thanks.Explain.
Explain
You don't just go to UL with a product to get certified, they say, "Yeah, we certify it" and you can slap the UL logo on your product. There's a paper trail somewhere, and that starts with a UL certification number.
Would that essentially make a neutral to case connection in the recep box? If so what about objectionable current? I know older ranges and stuff were 3 wire but what’s this used for?
I thought looking little strange also, the terminal identification. But looking @ front of device, it's denoting "duel voltage rating" 125/250V w/50 ampere rating.I tried to let the code articles and sections explain themselves. But I do agree, as others have pointed out, I wonder how it got listed like this as far as terminal identification . Something is definitely fishy about this. Please educate me. Thanks.
I'm going step aside now.. but.. Denote the silver terminal screw on the back. Straight 250V rated, both terminals generally same in pigment color. Believing that's what the "Green Tagger" is referencing, in his posting. Have safe day.
As far as I can tell, a NEMA 10-50R is a non grounding configuration. Which leads me to believe the receptacle is bogus using bogus UL info.
and probably doesn't have a valid listing. 10-50 is 50 amp 125/250 three wire non grounding designation, neutral is not bonded to anything but the neutral terminal of the device. Is/was permitted for connection of ranges where the appliance is allowed to be bonded to the neutral conductor.seems to be XIONGDA
Maybe China?
