Brian Johns said:I just refuse to backstab any device and honestly, i wish they would ban these types of connections, too many times have i pulled an outlet or switch only to have a wire pop out of the stab. I go so far as to tell my home owners that all of my terminations are done with twisted wires and wire nuts, and all devices are wired to the screw. It takes time and i think it is worth it.
every time a load is applied, that little pressure joint heats up, then cools, then heats up, i believe it takes the spring out of the metal, annealing it, thus a bad connection and just more heat the next time.
celtic said:Personally, I don't view a code compliant installation as "cutting corners".
Now if the people in the 350k home WANT all #12 run, then no back stabbing will happen....other wise, you get what you pay for.
76nemo said:celtic, man,........you are smarter than that book. I had this arguement with chevy just last week. I don't care what that book says, that book is a standard. I know you are above that standard celtic.
Like any employee, that would depend on what the particular EC wants done.GUNNING said:what do the union guys do?
Backstab or hook?
They use backwired devices with pressure plates.GUNNING said:what do the union guys do?
Backstab or hook?
celtic said:Like any employee, that would depend on what the particular EC wants done.
Unless, of course, you are asking a union EC what he prefers.
ohm said:What do you suppose would happen to a backstabbed receptacle with a bolted short?
ohm said:Call me crazy, I don't even install #14, especially after AFCI's were required. At $35 a breaker I want as many outlets as possible on an AFCI.
celtic said:If installed properly, wouldn't the OCPD trip?
I don't see what your point is here :-?
Are you paying for the AFCI?
ohm said:Yea the breaker will trip after it melts the stabs in the receptacles, just like the Kliens.
ohm said:And the less I spend on AFCI's the more is that is left over for numero uno.
I know that you said that you installed the switches, but I had a guy that kept cracking switches and outlets. Caught him using a 18v DeWalt drill at high speed, without using the clutch. Go figure.220/221 said:Removes most doubt.
I did a service call a few weeks ago on an installation I did a couple/few years ago. Single pole switches to a evap cooler/pump, 4s box/inustrial cover.
Both switches were wrapped of course and both switches were somehow broken at the terminals??? I have NO idea how it happened. Did I over tighten and crack them on installation? Doubtful, but who knows.
