i Installed 240v to a hot tub yesterday, with a disconnect using a single pole switch using the ground and the neutral to the switch in theory when the switch is closed it will trip the GFCI Breaker I have done this many times, this time it did not trip the breaker I’m clueless at this point I am going back to install ground rods! I found in the main panel there is a ground coming from the meter through a grounded bushing straight to the cold water ground, no bonding in main panel nor not good continuity between main and sub panel ! What would be the correct fix here? I’m thinking a ground rod at the tub! But most likely at the meter which a deck is built around?SMH???
