readydave8
re member
- Clarkesville, Georgia
- electrician
And longer to train HO not to walk there.Good grief! It might have taken quite a while to recognize that pattern of behavior.
If you were wrong, as long as you met the reasonable person standard, I guess you would have been covered.$16,000 to replace (600' well, fences had to be removed, cranes brought in etc.). Ultimately the entire run from the house to the well was bad as well as the pump - a walkway was torn up, trees were removed and flower beds destroyed. It was the most nervous I've ever been making a diagnosis. I had enough data to back it up though![]()
Oh I was pretty sure that there was a GFCI somewhere because the house was new enough, but it shouldn't have been in the bathroom. I made the mistake of using logic that day.:roll:
I did sorta the opposite, and the inspector was okay with it. I put a crawlspace receptacle on the bath GFCI for a bed-and-bath addition we built. It was there for the HVAC servicing requirement.I have found outdoor & bath receps fed by a GFCI in the crawlspace. Sickens me that an electrician would set up something for a homeowner to have to crawl under the house to reset a receptacle. Naturally, the HO may have never seen that recep, may not even know it's there.
