c2500
- South Carolina
Ok, the pool installers I had previously mentioned in another post got their permit. It is a fiberglass pool with only a light. I pulled the electrical. I spoke with the inspector the other day, and he said make sure I run a #4 insulated bonding strap through the conduit. (It was a casual conversation over the counter with no code books open, so I won't fault the error...plus we don't have very many pools around) I have since read it only has to be an #8 according to 680.22(B)(2)(b) (2005 NEC)
Well the bozo installed a #10 today. I want to scream. Also, as I am looking by flashlight, he has used a section of white flexible pvc that I don't think is rated for wire use. Then it goes into schedule 40 PVC that is electrically rated. They need to bury the light before they can proceed, and are wanting an inspection for the light. I can't wait to break it to them that there will be no calls for inspection until I see it wired correctly.
For what it is worth, in the State of South Carolina, ANYONE can install a residential pool. Only commercial pools require a license. The guy just had to get his business license to be able to pull the permit.
c2500
c2500
