ivsenroute
- Florida
Where in the NFPA 70 is there a requirement for electrical inspectors to cite a code reference when they fail an installation?
Then where is that stated?
BTW, Art 80 (Annex H) does not state that.
An electrical violation is no different than any other legal violation, I cannot be charged on a generality. The inspector has to cite a specific code and incident. No different than a speeding ticket.
80.19(F)(5)? Again this is not enforacable.
Failing an electrical inspection is not a citation that has to go in front of a magistrate, it is simply a notice of violation as to what the violation(s) is/are and can be described in written format. There is not a penalty in a notice of violation from a failed inspection like there is for a speeding ticket.
I am just curious as to where the requirement is found.
Actually, for me it is a violation that could go in front of a magistrate if I do not pass and /or correct a situation in a timely manner. I deal with dual electrical/fire marshalls that have broad powers in regards to safety in collegiate settings in VA.
So is this another urban myth?
Whenever an Inspector points out a violation on a job I always ask for a code reference.
Some will tell you what they want done and even admit that it's not a code violation, just common sense.
That should not be happening. If it is not a code violation, it should not be written up. Common sense or not. This is probably the biggest complaint from ECs
It sure hasn't been a problem with me. It has only happened less than a handful of times and every time I agreed with the inspector and happily complied.
Remember, if you follow the NEC to the letter, you are the worst electrician allowed by law, as the NEC is a bare minimum.
The moment we insist that inspectors become universally unwavering walking code books we have taken the human element out of the inspection process.
