jwelectric
- North Carolina
I have two, 5000, 7500 and neither one has one. Is this something new? Mine are about 10 years old.Side note: Everyone of those "cracker boxes" has voltage regulator.
ice
ice
I just left a room full of folks that disagree with your statement that the NTRL has enforcement abilities through 110.3(B)I stand by my statement that the NRTL does not have resonisbility for the enforcement of the standard after the product has left the manufacturing facility.
editI have two, 5000, 7500 and neither one has one. Is this something new? Mine are about 10 years old.
Where does their authority to enfoce come from? How can they come on to my property to enforce? What can they do to make me comply?I just left a room full of folks that disagree with your statement that the NTRL has enforcement abilities through 110.3(B)
But that is not enforcement by the NRTL...that is enforcement by the code adopting authority.Not trying to get into any kind of match with anyone but if you are under the ICC building codes then any equipment used in a residential setting must be listed. If it is listed then it must be installed according to any instructions included with the listing such as FTCN.
Now we can use any excuse we want to circumvent the codes but the liability will fall on those who do not follow the codes.
Does the ICC code really say any equipment used in a residential setting must be listed, or does it say installed. If it actually says used, it is totally unenforceable and likely not valid when adopted by a unit of government...that is if someone would spend the time and money necessary for court challenge.
That is much broader than 110.3(B) and does seem to require you to use only listed products....I really doubt that would stand up to a court challenge. Is there something else in the ICC that would make the requirement for listed products only apply to equipment that is installed? A requirement in a building code to require me to buy and used a listed cord and plug connected appliance would likely exceed the scope statement for that code.Well Don I ani't too sure about the word "used" but I do think it can be found somewhere in that section
E3403.3 Listing and labeling.
Electrical materials, components, devices, fixtures and equipment shall be listed for the application, shall bear the label of an approved agency and shall be installed, and used, or both, in accordance with the manufacturer?s installation instructions.
Thanks, but I knew about this site. I was hoping to find one that wasn't $149.95.(
Try National Ram Electrionics nattramelec.com
I found these and they work great. $69.00 free shipping 3 days.
Where ya been NHfire? haven't see you in a while.
Nice interlock kit George but "is it UL listed for use by the mfr. with that panel" seems to be the general trend of this thread. Some inspectors I've been talking with regarding these kits are asking other questions like "Does drilling out the panel cover have any affect on the functionability and integretity of the panel cover ?"; "How do you secure the 30 amp generator breaker so that it's can't be easily removed?"; "If you're using a cable tie will it become dried out and brittle over time and lose it's effectiveness ?"; "If you shut the main breaker off is it really off or do you pull the meter as well ?"; "Does the homeowner have the capability of pulling the meter ?"; "What if the meter enclosure is locked ?"Sorry to revive this a little late, but...
This thread (and the bad weather out east) got me going, so I installed one on my house.
Eat your heart out interlock, this one's $70 for two chunks of metal, a template and three screws from the factory.![]()
I would presume that it's UL listed by the mfr for use with that panel but I don't see any markings or labeling as such (as long as we're all nit-picking about this ):roll:The interlock in George's picture is a Square D accessory for Square D panels. I have installed one just like it.
I saw nothing in the panel permitting the use of the kit I installed. The Square D kit I installed did not claim to be listed for use in my panel. Look for yourself here.Nice interlock kit George but "is it UL listed for use by the mfr. with that panel" seems to be the general trend of this thread.
The factory solution in this instance required drilling the panel cover.Some inspectors I've been talking with regarding these kits are asking other questions like "Does drilling out the panel cover have any affect on the functionability and integretity of the panel cover ?";
The factory solution in this case is a cheesy metal strap that was bent (crushed) when I received it. It would take little effort at all to swing the "door" out of place and remove the 30A breaker."How do you secure the 30 amp generator breaker so that it's can't be easily removed?";
Since the factory used metal, that could be a valid complaint."If you're using a cable tie will it become dried out and brittle over time and lose it's effectiveness ?";
If the inspector does not trust circuit breakers to perform their intended purpose (assuming we're not talking about a physically seized old breaker), then I would report that stupid question to his boss."If you shut the main breaker off is it really off or do you pull the meter as well ?";
Yes it is UL listed for use with specific Square D panels. They make a number of models for different Square D panels.
http://www.homedepot.com/buy/square...tor-interlock-kit-homrbgk2c.html#.ULNXpRB5mSM
I paid $68, waited a week, and Bob found it for $46 same day pickup. Very timely Bob. :rant:
