dhalleron
- Louisville, KY
- Master Electrician/Senior Fire Alarm Technician
I've heard of them, but never thought much about it.
I need to drive a second ground rod to satisfy an inspector on this job. I already ran the wire to the first ground rod. How can I extend the #6 to the second ground rod without replacing the whole wire run with a continuous piece?
I don't know what they stock locally to do this with. I found a breakaway bolt on the web but it seems like it is only tamper resistant. What do you use to make the connection permanent that won?t make me buy a special tool?
I can run a new wire but it will take about 45 minutes or so.
Thanks,
Thanks,
