hill900505
- Texas
Greetings :bye:,
After a feeder tap wire is terminated to the line side of a fuse block, can I run a smaller size- another tap wire from the load side of the same fuse block to a smaller sized fuse block then connect to the load? Both tap wires are less than 10' and comply with 240.21(B) as far as ampacity goes. Is it a code violation because I am tapping a tap wire? I found a fused distribution block on Cooper's website. http://www.cooperindustries.com/con..._distributionblocksterminalblocks/j-pdfb.html
