jim dungar said:But, for the sake of general electrcial theory consistency, why would you say that the current caused by a purely resistive circuit is 180 degrees out of phase with the voltage?
I still find it easier to describe a 120/240V system as two 120V circuits connected +-+- rather than as +--+.
Jim, I don't think I said that, but one might think so if one does not pay close attention to phase angles, references, and the sense of the current.
Agreed, for a simple 1-ph problem your method is easier and quicker.
But, for a 3-ph problem, none of the voltages is the negative of another, therefore you have to use the individual phase angles. I contend that this is the general approach if there is one.
Whatever, it is perfectly acceptable to label V2 as 120V@180 (re N of course). And, yes it is a 180 degree phase difference from V1. Any argument to the contrary is baseless.
