I don't do residential, but I like to energize all ckts if possible prior to sheetrock (as long as its 120v). If they hit my wires I want to know it and I want them to know it.
OK, let me try this angle:
Let's say here's a panel and a 15a general purpose circuit.
Where does the tester go, and what do you do to test continuity? Keep in mind, this is a rough-in, so no devices are installed.
(pa3b)hummm ---slap them around the block (with a nerf bat) Maybe they should have been on point - you too:smile:Gentle reminder, not everyone in a thread is responding to the original poster.---.
..........In most cases it would be easier to hot check it with temp or generator power.
!7 posts and not one has tried to answer the question asked. :roll:
Perhaps a small 120 volt relay added into the circuit that would open your circuit to the LV source if 120 was applied.
Really you may just have to be more careful.
17 posters did not have an answer. What about an inline milliamp fuse.
I'm still trying to figure out where the 120volts is even coming from.
well first you have av expanding and contracting magnetic field......
I am with the single poster that wondered why the conductors weren't labeled before they were pulled.
I use a radio shack personal alarm as a ringer, so i can hear it from far away. But i've fried to of them when 120v got sent through it on accident. So i was wondering if i could put something between the alligator clips and the personal alarm to protect it from happening. Also what do you guys use for a ringer when you need to hear it from far away?
PJ and a pair of cell phones.Also what do you guys use for a ringer when you need to hear it from far away?
Easier how?
Sorry...not easier, ...more efficient. Continuity only give you part of the story.
I wouldn't test an entire house but in a simple room addition for example, I would make up everything and screw light bulbs in the cans/test power at the light boxes.
I think it got off track in the beginning. The ringer is simply used to test continuity, not necessarily to ring out an entire house (although it could be).
In my case, the 120V came from a breaker I turned on.
I was ringing out some wires in a commercial conduit job. I had it clipped to a set of wires that I thought went to location A in another room but they went to location B...the panel.
OK, so if there's 10 lights on 10 switches, how does your tester tell you if there's a problem with 9 of them?
So you fried one when you failed to properly test for the presence of power?
