Re: Is this considered a Sub-Panel or Not?
Steve, draw out the buss duct, the Grounded Conductor is the same at both ends as far as the continuity to the metalic enclosure, so bonding it at both ends doesn't change anything. There would be no need, reason, or advantage to seperate the Grounded and Grounding counductors anywhere within this service equipment.
Let's all forget about the code for a minute.
BTW, Sam you would be better off looking at 250.142 as far as a code reason.
Roger
Roger
