billdozier 78
- Orlando
If you have 3 circuits in one conduit all calling for isolated grounds how many do you pull? To me I would pull one eg ground and one ig which would then pass through each box to individual duplex receptacles.1
Not an NEC requirement. In fact, the NEC don't require anything different than "regular" EGC's. The NEC just permits IG EGC's to not be connected to normally-non-current-carrying-metal parts along its route.... Also, keep in mind that in any event that the isolated grounds must pass thru (not connected to) any sub panels and connect at the service bonding point. ...
This would be a design issue, only. The NEC does not describe where isolated grounds begin, or end.Also, keep in mind that in any event that the isolated grounds must pass thru (not connected to) any sub panels and connect at the service bonding point.
I did not mean to imply that it is a NEC requirement, just that if you don't they are pretty much worthless.
One can argue that it is a rare instance where isolated grounds aren't pretty much worthless as is.
