To whom is that addressed ?Did you mean to say KWh instead of KVA?
Yes you, sorry I thought I quoted you.To whom is that addressed ?
Then no, I do not mean kWh instead of kVAYes you, sorry I thought I quoted you.
Okay well you said KVA at first, and I must have quoted you before you edited it and corrected it.Then no, I do not mean kWh instead of kVA
If you read what he wrote...he's not correct.He is correct
kW is horsepower
kWh is gallons of gasoline
This question is like asking, how can I tell how many horsepower my car has by how much gas I put in it?
It still says kva. And you are correct, it is still wrong.Okay well you said KVA at first, and I must have quoted you before you edited it and corrected it.
Think of it as rate - not energy.It still says kva. And you are correct, it is still wrong.
Typo? He's insisted in post #23 that he meant kva, not kwh.Please don't get caught up in the typo. See post 3 vs post 10. Beo clearly understands the difference between kW, kVA, and kWh.
Thank you kindly, Mr Winnie. Now I have done with this topic.Please don't get caught up in the typo. See post 3 vs post 10. Beo clearly understands the difference between kW, kVA, and kWh.
So, your are saying electrofelon was correct that you were mistaken?Thank you kindly, Mr Winnie. Now I have done with this topic.
Yeah strange. I thought it was a typo at first, I scrolled back and thought it had been edited to "KWh" but I must have been looking at a different post. He definitely seems to be insisting that KVA is energy.Typo? He's insisted in post #23 that he meant kva, not kwh.
Without quoting reference posts it is easy to get confused.Yeah strange. I thought it was a typo at first, I scrolled back and thought it had been edited to "KWh" but I must have been looking at a different post. He definitely seems to be insisting that KVA is energy.
Well, might as well get my two cents in..Ok I think I hope we all can agree:
KWh is energy
KWn is "kilowatt nanoseconds" used to measure large amounts of energy
KW is power
KVA is close enough power
Evans a load calculation can be problematic. If all you need to run is a heat pump that has an MCA of 25 amps, a 25 amp generator most likely won't start that hvac unit. Similar issue with any big motors like a well pump.
In most applications, a load calculation will provide a number much larger than needed. My house which has a load calculation of 150+ amps rarely draws more than 30A on a given phase. Most of my appliances are gas though, so that helps a lot. But the air conditioner has a locked rotor amp draw of about 110 amps.
This can depend on the prime mover of the generator to a certain extent as well.Evans a load calculation can be problematic. If all you need to run is a heat pump that has an MCA of 25 amps, a 25 amp generator most likely won't start that hvac unit. Similar issue with any big motors like a well pump.
We do when our backup generators are inverter based.We don't really take LRA into account on residential like this. ...
