peter said:I would suggest you put a handhole or something at the 398' point.
~Peter
ceb58 said:You are looking at 3.15 to 3.30 per ft. You did not say if you were including pull boxes, ells this would raise the price. Best way is price out material in your area, ad mark up, figure how long you think it would take to make the pull and add it up.
peter d said:Primer? What's that?![]()
Thats the dielectric !peter d said:Primer? What's that?![]()
Mule said:and Glue? what do you need that for?
peter d said:I think the glue is a lot more important than the primer.
Mule said:Does the glue go on first, then the primer?
quogueelectric said:400' would be max for 1" to groundbox learn to use a vac and baggie w jetline it will save you lots of money in the future. Setup for 6 500' spools should be all of 5 minutes.
frizbeedog said:No....first the glue, and then the glue. What primer?
:smile:
peter said:However: the 800 feet could make this a pull from [German word for "bright"]. I would suggest you put a handhole or something at the 398' point.
~Peter
growler said:Why do all of that. You can make an 800 ft pull easy enough if it's only 3 ea #8s and 1 ea #10 in 1" pvc. Where people mess up is putting factory 90's on the ends before pulling the cable. If you just leave the conduit sticking straight out of the trench on each end, pull the cable first and then install the 90's it's much easier. Friction is what kills a wire pull and every bend developes friction ( so don't have any if you can keep from it ).
It's easier to pull through 800 ft of straight conduit than it is to pull through 400 ft with say 180 degrees of bend in it. If the people feeding know to keep the conductors straight and there are no dirty couplings and gravel. Lots of good wire lube to reduce friction and it's a piece of cake.
Calling all carsgrowler said:If you just leave the conduit sticking straight out of the trench on each end, pull the cable first and then install the 90's it's much easier.
