JFletcher
- Williamsburg, VA
Hal, you mentioned Decora switches... Worst switch ever. I'd be willing to bet that if you rock the switch from side to side or from corner to corner, you would see the lights flicker.
One of the craziest switch troubleshoots I was on was a few years ago, with two 3-way switches controlling a hallway light. switches work fine for about 8 Cycles, then the hallway light stayed on regardless of either switch's position.
Long story short, both three ways were bad and it was only found by accident when I pressed on one at the corner of the switch, rather than the center, and broke the contacts inside the switch causing the hallway light to go off. Also have replaced Decora switches on higher amperage loads like garbage disposals.
I have noticed a tendency with homeowners to smack a Decora switch with the palm of their hand, rather than operate them with their fingers. not saying that is your exact problem, however I have definitely included it as part of my troubleshooting protocols.
