hmmm, profile lists 'engineer'? An engineer afraid to hook up a scope to simple 240 V 60 Hz? Untrained and an engineer? a locomotive or 'sanitary' engineer?
All you need to do to get your full data is to hook up a scope with a current probe (you don't even have to touch any 240 V wire with a clamp on probe) and look at the waveform. You will undoubtedly SEE a differential current at transitions.
Gar probably has already taken some waveforms and waiting to see if any others have
Using a small SP motor I see differential currents in the 10o's of mA at switch operations.
Another hint: the inductance of small sp motor is 500 mH, a 1/2 HP motor is only 2.6 mH - what does that tell you?
I was engineer 25 yrs ago but left the field and went to medical and neuroscience after I realized that the most advanced electronic in the universe is a cell and it's nanotech.
But after learning lately our country doesn't have EGC in any appliance. I tried to go back to it once again to try to be familiarize with GFCI to help protect 108million filipinos who don't know the concept of EGC or GFCI.
I'll try your idea after finding someone with oscilloscope, especially since we will be stuck with that only brand of 240v GFCI in the world for the next 30 years. I don't want to buy one just for it because after that, what would I do with an oscilloscope afterwards, I don't want to try it on other items as I don't want to take any risks with electricity. One wrong Zap and you don't wake up forever.
That said. I'd like to focus on something now.
The typical time/current for class A GFCI in USA products are controlled by UL. But with the 240v GFCI OEM made by an unknown manufacturer in china using cloned chip and distributed worldwide as OEM, I want to make sure the time the relay opens is as good as the USA GFCI products.
This is the relays and sense coil of the 240v china GFCI (or the Meiji GFCI outlets we have).
Notice there are two solenoids compared to the USA GFCI with only one like:
The Leviton one has only one solenoid
I takes time to build magnetic field. I just wondered why there were two electromagnetics in the china GFCI. Anyone has theory why two? The contacts just goes up and up. The top solenoid probably attracts the contacts upward, but why is there another one on the right? A seasoned electrician I asked doesn't know why either.
Remember the circuit diagram (for both which is identical) only has one solenoid:
Also with an oscilloscope, how can you measure how fast the relay open when there is current imbalance. When I find someone with oscilloscope, I'll try to figure it out too.
