I am talking about code compliant vs non-code compliant.A customer want to replace a non-grounded recptacle ,I can put a grounded type receptacle in but it would violate code,I could run a ground wire by itself back to the panel,which would make it better but would still violate code.I must replace it with a GFCI or a non-grounded receptacle.I don't have to rewire the house I just have to know what the minimum the code allows
Just for the sake of argument How do you'all (yankees included) switch from wiring inside the house (or any structure) to outdoor wiring??? What is the "code approved" method for installing a outdoor surface mounted bell box GFCI.. Is a surface mounted bell box (or any J-box) considered a wet location??? Give me solutions__ I already am aware there is a discrepancy.
Yankee Solution:
Inside...EMT to exterior bell box, LB, or Pull-El.
Outside...EMT above grade, or RMC below grade.
THHN/THWN copper wire on the whole run. Personal favorite is stranded for easy pulling.
I agree if you installed everything to the letter of ALL codes you would never get any work done and price yourself out of customers.Rewire...with all due respect, this whole discussion about NM conductors not being rated without the sheath, and you cant put them in flex, is a bit silly IMO, but that's ok...to each their own..
Seriously Im not here to argue with you about anything because lifes too short... but you cant tell me it was unsafe. You can tell me it did not meet the letter of the code ...but seriously??
Im backing out of this one......have a good evening............:smile:
signed.....dangerous, stupid, no exuse, and what was it? oh yes "totaly going against the code"
Yankee Solution:
Yes, what you said. Only around here in New England I would never install EMT outdoors. It rusts out too quickly and looks like trash in a few short years.
I have never had EMT rust on me.
I live in Colorado where it is sunny one day, snows the next, and is sunny the following day.
We experience dramatic temperature changes, which would lead to issues in this regard. However, I have installed EMT outside, in Colorado, for over 9 years now... (that's how long I've been here) and have not seen EMT rust.
I put it low, next to the ground... I put it high, on top of roofs...
No rusting here...
Forgot about the coastal areas...We have salty air here...EMT simply does not last.
It may be silly but it is not 'to each their own' it is code. :smile:
"our inspectors dont make calls like that"
I don't think anyone did say it was unsafe, I did not.
Ok, my apologies ...
It makes no sense in these lawsuit happy times to violate the code. It also would only have taken a walk to your truck to fix it code compliantly.![]()
I wired new machines with extensive use of liquid-tight conduit and fittings. I've only use it occasionally since, but never had a problem with the fittings. Maybe it's "operator-error".
The plastic stuff PVC....These fittings had a hole in them about the size of a pencil maybe a sharpie at best....
Try the metal fittings next time Mule.
Thanks.......I dont plan on using that junk any more, going back to standard liquid tight......the real deal...
