 - Massachusetts
zog said:It is that easy, if you read the OP's question.
Right.
But the issue is that you have decided the only "qualified definition" is the one that you work with.
In other words "My standard is better then your standard"
iwire said:Right.
zog said:Not at all, it simply is the answer to the OP's question.
I'm looking for a qualified definition for Voltage levels ie. Low Voltage < ? Medium Voltage > to < & High Voltage > ? There are various definitions for these in the NEC & NFPA - Is there a definitive answer for construction, maintenance & utility electricians? Is there a standard and if not why not?
Is there a definitive answer ...
iwire said:is no, there is not a definitive answer.
zog said:True, but there should be
George Stolz said:My question is, what's in a name?
iwire said:Yes, that would be the ideal solution. :smile:
They might have to add an 'Ultra Low Voltage' category for 0 to 120.
spark2 said:Is there a definitive answer for construction, maintenance & utility electricians? Is there a standard .....
spark2 said:..... and if not why not?
charlie said:I am having a problem with the reason this is such a great consternation since you would use the scale of the code you are working with. The IEEE scale would fit with the NESC since the IEEE publishes the NESC. Use the scale that the NEC uses when using the NEC.![]()
iwire said:I consider myself a construction and maintenance electrician and the NEC, not the IEEE rules what I do. That being the case using the NEC definition makes the most sense. Building construction, maintenance electricians know little of the IEEE, we don't have to. The IEEE is not the standard we are required to work to.
If I worked on utility type equipment then I imagine the IEEE would become my 'go to' standard.
zog said:Yep, the difference is I answered it
dnem said:"I know there are many answers and none can claim to be the only right one. . Here on this website, the best answer is the NEC answer.
dnem said:I know there are many answers and none can claim to be the only right one. . Here on this website, the best answer is the NEC answer.
zog said:So what do you call this?
zog said:Thats a good ise but I propose 2 lower voltage classses, to more easily comply with OSHA and NFPA 70E EEWP's.
120-600 - Low voltage (As it is now per IEEE and parts of the NEC)
50-120 - Some new class, maybe "extra low voltage"?
<50V - Something new, "irevelant voltage"?
dnem said:I'm glad this thread came up because it not only gives an answer to spark2s question, but also gets the rest of us thinking. . A more accurate answer is always better.
ELA said:I often perform bench testing and want to alert people to a possible hazard. I often put out a sign that states " Caution - High Voltage Hazard" even when there may only be 120 -240Vac present. It is intended to make a point that the area is to be avoided.
Using the phrase "Caution - Extra Low voltage hazard" just does not have the same impact. :grin:
ELA said:I think a lot of computer engineers would take issue with your proposed catagory of
"<50V as irrelavent".
You seem to be totally focused on what is relavent for your world only. There are a lot of different users of the term "voltage" and it will always be relative to the industry you work in.
zog said:I meant irrevelant in regards to Electrical Safe Work Practices as defined by OSHA and the NFPA 70E (As I stated). <50V does not require PPE or the system to be denergized, therefore from a safety <50V is irrelevant.
